I don't hate them exactly, but none of the ones I've looked at really fit the style of the Cutlass in my opinion. Plus, as I'm going to replace the wood grain trim with gbodyparts' brushed aluminum style trim, I'm going to sand the brown crap off the wheel and brush on some silver enamel paint so it'll match.
Your dad did a pretty boss job on his wheel, from the looks of it.
As for the engine, I'm mainly going COMP on the valve train. Specifically:
CCA-42-433-9 hydraulic roller lifter cam with .515/.533 lift, 290/296 adv. duration
CCA-857-16 linked roller lifters
CCA-1442-16 roller tip 1.6 ratio rockers
CCA-2113 double roller timing set - I was originally planning to go with a Milodon gear driven timing set, but that was when I was considering supercharging it. After I nixed the 'charger, I decided to save 400 dollars on the timing gears as well.
As for the rotating assembly, I'm probably either going with Eagle's SIR forged 5140 i-beams or SCAT's forged 4340 i-beams, as I'm having the crank ground to accept Chevy rods on account of having no other option when it comes to new steel rods. Piston wise, the machinist suggested getting some custom forged aluminum flat tops from Ross Racing Pistons with a .927 wrist pin hole instead of reaming out the connecting rods, as he assured me that doing so was going to be a huge pain in the *ss. As a machinist myself, if someone who is my superior by virtue of having more years of experience than I've been alive says something is way too much work, I take their word for it.
On the intake side, I'm putting in an Edlebrock Performer RPM manifold on account of it being the go-to choice for pretty much everyone intent on building a solid sh*t-ripper. I'm also deciding on if I want to rebuild the original Quadrajet to top it off, try to figure out what the hell my uncle did to the Demon he sold me then use that, or just say "**** it" and stuff on a 650-750 CFM Edlebrock.
As for the heads... I'm having the machinist deck the hell out of those 8 heads, shaving off 10 CCs and about .060 of stock, aiming at 9.5-9.6 compression with a .043 compressed thickness gasket. If it goes too high I can always drop on a fatter gasket. After that, I'm giving them a rigorous porting for better flow, though from all reports the 8 heads weren't too bad on that front with the EGR bump removed. If worse comes to worse, I'll fork out the dosh for a set of Edlebrock's Performer heads, which seem to be viewed as pretty fantastic, and just stuff the 8s on the 307 in place of the worthless 7As it currently has.
As for power expectations, I plugged what I'm going to do as accurately as I could into Desktop Dyno 5, which isn't exactly the most accurate simulator, and it gives me a guesstimate of about 339 peak flywheel horsepower and 410 peak flywheel torque. If I get anywhere near those numbers I'll be thrilled, and, at absolute worst, it'll still be better than the 307 with the added benefit of being a freshly rebuilt, reliable engine. Not a very gas friendly or smooth idling one, but hell, if I wanted a smooth, quiet, fuel efficient vehicle I would have bought a Toyota Yaris.
