More cubes is best cubes, after all! I'd like to do a stroked Olds engine at some point, but for right now I'm just doing a fairly vanilla stage 1ish decently high performance engine.
I also got a Hotchkis steering rebuild kit, tie rod sleeves, a Dorman pitman arm, and a set of Eibach pro-kit lowering springs on the way from summit, so as soon as I yank the 307 I can crawl all up in that b*tch and rebuild the steering with bearings and bushing that haven't been lubed maybe three times in the past twenty eight years. Now I just need a good rear end with 3.73ish gears and Posi, a clutch, and a auto-to-manual conversion setup, and I'll be good to finish up the rollin' bits.
I wonder if GBodyParts has any GM 8.5 rear ends in stock? Hm. Not quite as beefy as a Ford 9" from Quick Performance, but about a thousand dollars cheaper and a proper GM part.
