Stock bottom end, keep it under 5,000. 😛Found the bolts, and here's the info from TA Performance.
This intake is the best choice for 400+ HP combinations that will be street/strip or full race with power bands that peak between 5000 and 6500 RPM. Performs equally well on the street as well as in competition, this single plane intake manifold makes power from idle to 6200 RPM out of the box and with a match port job this intake will run to 7000 RPM. The runners are long and narrow to keep velocity up, and the last 2-3 inches of runner are straight to direct the air and fuel right at the valves. This means faster airflow and less fuel dropping out of the charge, which results in better throttle response and less low end power loss normally associated with single plane intake designs.
Like you said, it shouldn't be a problem. It's the only single plane intake I've seen described as making power from idle, and I will be making more than 400 HP, so this was a no brainer for me. Not to mention the cost.
But that intake certainly seems like it will support many future modifications. Great deal.
