Show us...I love the fast back g body I have a 79 cutlass notch back that im cloning into the 10th anniversary car and I want to do a t top conversion I know from 81-88 the b pillar is different but any clue if this is true for 78 - 80
No frame notch on this car, but I will be adding all of the frame braces that are available for the G Body.Good deal. Will you be boxing or modifying the frame at all? I want to weld on a brace up front that mimics the UMI piece and I see folks adding a tune up by the rear shock tower as well. In addition to boxing it and narrowing by the rear wheels to make room for more meat.
The control arm braces tie the rear upper and lower trailing arms together. It really does help. My Cutlass frame isn't boxed or notched, but has pretty much every suspension and chassis stiffening product on it.....it is stiff! Between the massive front sway bar and rear shock brace and pro touring sway bar there should be no body roll!What are the rear control arm braces and body braces?
