PROJECT " LAID BACK 2 " - 1978 SALON 2 DOOR AEROBACK
KCP
421
1,004
Bavaria, Germany
Good score!
Wish we had any real salvage yards left here, most of them had to close for enviro reasons. The ones remaining just stack Euro cars. I already thought about buying a Blazer to part out, but all you get here is 4WD since these were the only ones officially imported back then.
JAMCAR223
1,853
5,507
Houston, TX.
Well guys I was going to show you a pic of all the tune up parts for the 260 V8 in this car, but what's the point when you have better news...
Today I scored a Olds 403 long block with an Edelbrock Performer RPM manifold. So I was searching FB Marketplace, and came across an ad for an Olds 350 Rocket Engine - $250. It looked pretty clean, and the pics showed complete long block, balancer, crank pulley, water pump, oil filler tube, oil filter adapter, flexplate, oil pan, Edelbrock intake, rocker arms, and all the bolts were there. I was interested... I looked closer at the pics, and he had scrubbed the area where the casting number was.. 557265. So I ran the number.. It's a 403! I expanded all of the pics, and the heads are stamped 4A, plain as day. So I contacted him last night, and set up a time today to go check it out. When I got there I could plainly see "403" stamped on the side of the block... Is this guy blind?? I grabbed the crank pulley, and the motor turned right over by hand. I said nothing but "I'll give you $200 for it all" He said OK, he wanted it out of the garage. SOLD!
The motor was on a rolling engine stand.. he gave it to me. Thank you very much!! He had a hoist, so we loaded it up. Here's the pics.
So the plan is to give it a solid rebuild, using stock style parts. Deck the block, mill the heads to bring up the compression a little. Install a nice sounding/performing cam that works with this intake, and 3.42ish gears. I have a 750cfm Quadrajet I'll have spec'd for this combo. The distributor, and accessory brackets from the 260, will work. I will probably use Thornton exhaust manifolds, and rob the Jegs 2.5" dual exhaust kit I bought for the Century ( the 462ci BBB could really use a 3" inch exhaust anyway ). It will probably take me a year to assemble this engine. I got too many irons in the fire. BUT, I will have more for you tomorrow...
Reactions: 15 users
1evilregal
3,056
4,357
Greensboro, NC
killer score! pays to do a little research!
12,181
9,811
Wow!! You stepped into it again....nice going. You've had some really good luck lately. Nice start to a good year.
Turbo Zach
2,534
5,874
You need to play the Lottery! I am starting to feel a little hatred towards you from envey. You're going to need a bigger garage!
KCP
421
1,004
Bavaria, Germany
Nice score!
JAMCAR223
1,853
5,507
Houston, TX.
I know, right... the guy didn't know what he had.
I did. It's the only way I can afford to build these cars.
:giggle: I agree on the bigger garage. When I lost my shop space 4 years ago, due to a construction project, I have been at a loss for space around here.
Nice score!
I agree. A couple good things... Easy swap SBO to SBO, gaining 143 cubic inches - NICE! And it's period correct, 1978 to 1978.
JAMCAR223
1,853
5,507
Houston, TX.
So these are the tune up parts I was going to mention yesterday, but I was too excited about finding the 403. I will still tune up the 260, because It runs and drives, and it will be a minute before I can swap in the 403. During that time, I still want to be able to use the 260 to move this car around the block, periodically. The oil is BLACK, and no telling how long it has been in there. The rear view mirror had fallen off, ( probably due to sitting in the sun ), and had cracked. I dug my last Compass / Temp. rear view mirror out of my stash ( complete with plug, and sensor ), and will install it. I'm going to check every fuse, and every bulb in the car, and replace as necessary. I want everything working on this car, including the A/C. ** I forgot to put the spark plugs in the pic.. AC Delco R46SZ **
I will have more tomorrow. I'm expecting a delivery...
19,996
compass mirror?
oldsmobile joe
2,067
3,053
mpls
