PROJECT " LAID BACK 2 " - 1978 SALON 2 DOOR AEROBACK
7/16-20 up to '81, the rotors are '78 only due to the bearings.
Whoops. Yup. '82 is when GM went metric on the lugs. Do you happen to know what the 'knurl' size is so we can point him to the right parts? Might be different front/rear.
Does a '78 use different ball joints, or can he swap in '79 and later knuckles to save hassles down the road?
The ball joints are the same '73 up so there won't be an issue with the knuckles/spindles. As for the knurl I can never remember what it is for the studs.
So switch it all over to S10 Blazer ( spindles, hubs, rotors, calipers ), buy longer studs for the 1.5" spacers, and I'm good??
Reactions: fleming442
As you go through yor car, identify stuff the is broken, or in an unknown state. Spend the money to fix the broken stuff first, but pause an recognize when an upgrade now saves money later. For example: the wonky 1978-unique rotors, wheel bearings and steering column. If the ball joints are in good condition, safe for now, then you can split them from the knuckles and drop the whole mess in the trash. GM elected to replace the traditional spindle with a packaged wheel bearing and hub assembly, but because the F-body, S10 and Asto van used the GM midsize chassis and suspension common to the A/G body, magically, stuff interchanges with very little modification.
At minimum, you will need the knuckle assemblies from a 2WD Blazer (not pickup) 1998-2003 only. Sometimes these can be for sale form the Forum, but see what's in Houston - the 2WD version is going to be more common down thataway. If the rotors and calipers are good, reuse them. The hubs may be good or they may be shot, and they can be $50 $120 each depending upon your level of quality, but they are easy to replace later once you start driving, so perhaps you can use the as-found and upgrade later. There are several Blazer brake Forum threads that will be easy to chase down.
The Blazer hubs will have metric lugs, so consider also upgrading your rear axle shafts and choosing the later version set up for metric studs. To upgrade later, since you will be using adapters, for now you can obtain longer 7/16-20 studs and matching lug nuts for the rear. I recommend you upgrade from the stock ones to the 'acorn' style which has a larger shoulder to bear on the wheel adapters. Something like this, but I have not bought from this particular vendor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&toolid=10001&campid=5335822911&icep_item=253767300452. You'll eventually probably want to replace the master cylinder, and I have lately read about the right-hand drive S10 units a l;ot on the Forum. Not sure about the brake line thread pitch for a 1978 whether it will be compatible. Finally, if the car will sit for a while, don't drop money on new tires unless the current ones are leaking.
My kids want me to build Legos now, so I'll sign off, but forage the Forum and keep us informed. There's no need to upgrade everything all at once.
looky what I found.......
http://rocketfin.com/resin_product.cfm?id=2720
NICE find. Daddy like..
So it was 50% off at the J-Yard this weekend, and I was off today.... A 2001 Blazer made it's donation to Project Laid Back 2. I went just for the brakes, and thought I was going to strike out. I passed (2) 2WD that had the wheels still on, and with them up in the air, I could not remove the wheels ( I don't have a cordless impact ). After trying to shove other wheels/tires under the Blazer tires for leverage, I could not break the lug nuts loose. The last row... I came across the 2001 with the wheels removed. The suspension was very clean. It was actually a pleasure to work on. Less than 30 minutes, and I was gone. Spindles, hubs, rotors, calipers, and pads. With core charges, and tax = $99.04
I will clean and paint these soon. Thanks to TURNA for the link for the extended wheel studs for use with the 1.5" spacers, and Camaro wheels.
