PROJECT " LAID BACK 2 " - 1978 SALON 2 DOOR AEROBACK
JAMCAR223
1,853
5,507
Houston, TX.
Guys, not trying to scare anyone but hope y'all have better luck with the Detroit axle hubs than I did. Mine only lasted a couple hundred miles before making noise!!!! I thought I had a clamping issue with the caliper, but it was the hubs.
I went to Napa and forked out loot on Napa house brand which are actually SKF units.
Scott, Did you just decide not to screw with Detroit's warranty after your experience?
Jim Rockford
308
523
Shelby,N.C.
Little tip for installing springs, attach to lower control arm at the spindle and jack up the inside of the A arm where it forks and attach the pivot points , VS trying to attach it from the ball joint end.
spidereyes455
790
1,648
Northeastern PA
That's how I always do front springs and I never need to use a spring compressor. Though that method doesn't work if there's no front clip on or no engine in the car.
JAMCAR223
1,853
5,507
Houston, TX.
^^^ Exactly.
8,235
17,721
P*ssies. Just borrow some of those plastic tie-wrap handcuffs from the Portland, OR police. They sure as hell ain't going to use them. :)
37715135_2010647508966014_4148141708682461184_n-jpg.48634
  • Wow
Reactions: 12 users
Jim Rockford
308
523
Shelby,N.C.
  • Wow
Reactions: 7 users
JAMCAR223
1,853
5,507
Houston, TX.
Couple small parts today. I went to O'Reilly and got new motor mounts & transmission mount. Just cheap stock replacements, but they do have a lifetime warranty. All (3) for $23.45. Not bad at all.
JAMCAR223
1,853
5,507
Houston, TX.
You sure did. Unfortunately, the transmission mount is China built. :(
  • Sad
