So, while I was rummaging through a customer's parts pile, I found an aluminum oil fill cap with a -6 AN nipple on it. It must be for what you guys are talking about.
Any idea how it was plumbed ?So, while I was rummaging through a customer's parts pile, I found an aluminum oil fill cap with a -6 AN nipple on it. It must be for what you guys are talking about.
Fuel line is finished. Bought a fitting that uses a compression sleeve of sorts to go on the stainless steel frame mounted lines, and converts to AN. Then a sweep, filter, braided hose, back to a sweep, and onto the fuel rail.
does that have two piece ferrule compression like the swagelok's? that stuff's great.
Nope, it was brand new, never usedAny idea how it was plumbed ?
Wonder why. The more you look around at pcv setups for LS motors the more you end up confused.Nope, it was brand new, never used
$20 is for me. Easy to get through the firewall?Throttle cable is an Ebay special. 36" seems to work ok. Scott is using the same one.
LS1 Chevy 36" Stainless Steel Black Throttle Cable 4.8 5.3 5.7 6.0 Engine LS | eBay
Find many great new & used options and get the best deals for LS1 Chevy 36" Stainless Steel Black Throttle Cable 4.8 5.3 5.7 6.0 Engine LS at the best online prices at eBay! Free shipping for many products!www.ebay.com
Don’t be, exactly the same plumbing setup as was used in the 60’s. Two lines, one for when cruising with vacuum that’s hooked to pcv and behind the throttle plate. And a second line for WOT or low vacuum from a valve cover to in front of the throttle plate.Wonder why. The more you look around at pcv setups for LS motors the more you end up confused.
Yes, had to use a small fender washer on each side of the firewall, and enlarge the hole for the cable to fit thru. Could've just used a larger fender washer but didn't like the look of it. Cut my original throttle cable and pulled the little plastic retainer off that keeps the cable in the gas pedal. Also had to ever so slightly file the barrel down to fit into the cam arm on the throttle body. Might have just been a burr on it.$20 is for me. Easy to get through the firewall?
