BUILD THREAD Project long time coming
No idea, but I would venture a long time, bare minimum of a year. I did put Lubriplate on the cam, rockers and pushrods when I swapped the heads
There ya go - it can run for a minute or two with no oil pressure before you should be concerned.
Planned on changing the oil after the first 30 minutes of running to help flush everything out.
Picked up my driveshaft today. Was kind of excited for this.
Bought a used driveshaft from a 2004 GMC Envoy XL.
Guess what? It takes the same exact u-joints as not only a G body, but as a F body too. So the T56 yoke fit right on, rear joint was the same, just needed to be shortened to 47.5" for my application. But these would be a great upgrade for any G body and it saves a TON of money versus having one custom made.
Geesh Jared, you act as if he should be concerned about not having any/enough oil pressure??? I don't see any reason why those purple valve covers won't fit onto the next motor.
That's my point. This didn't seem like a Roadkill special to me. After my experience with my truck, never again.
Fuel line is finished. Bought a fitting that uses a compression sleeve of sorts to go on the stainless steel frame mounted lines, and converts to AN. Then a sweep, filter, braided hose, back to a sweep, and onto the fuel rail.
