Rktpwrd
Builder of Cool Shjt
4,171
23,921
Calgary, Alberta, Canada
Well THAT got outta hand in a hurry....
I think maybe I had too much coffee tonight!
Explanation and update to follow tomorrow as soon as I get a chance.
Stay tuned...
D.
  • Wow
Reactions: 13 users
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,177
9,779
Gainesville, Fl
D,
I hope you're not losing it....but knowing you, I'm sure there's an alternative plan. :oops:
1evilregal
3,056
4,357
Greensboro, NC
well, looks like cruisin season is fini.......
:popcorn: let the mods continue!
Rktpwrd
4,171
23,921
Alright, I’m sure I probably startled many of you with those pics I posted last night, but I assure you everything’s ok.
I haven’t completely lost my marbles, at least not yet. There’s a perfectly good reason things look the way they do in those pictures, but of course for it to make sense, I’ve got to start at the beginning.
Over the last few weeks, I’ve been working on making the templates and sheet metal pieces that will become the basis for my flush mount marker lights in the front fenders.
It started out by creating a template from some shirt cardboard. After taking measurements of the lights and fenders, this is what I came up with:
After cutting out the areas where the lenses would protrude, I did a quick test fit. The opening for the amber part of the lens was a tad on the small side, so adjustments were made until it fit nicely:
Precision is the name of the game here. The better and nicer I can get the templates to fit the lights now, the less guesswork there’ll be when it comes time to fit the lights in the actual pieces.
Next step was to cut out the outside dimension that the patches will be:
Satisfied with the fit and finish, I traced out my templates onto some sheet metal. I learned a long time ago to make it easier on myself and to always make both sides at the same time whenever possible.
I chose a little heavier gauge than I normally would, and heavier than what G body sheet metal is. Probably somewhere around 18 gauge. I’ll get more into why a bit later.
There’s a slight taper to one edge of each of the lights, so the driver’s side was made a mirror image by simply flipping the template around and tracing from the backside. To prevent future confusion, they immediately got labeled as to which one was which and then were cut out around the outside:
Next, before I could consider going any further I had to start to shape the patch to match the contour of the fender. Since I’m working on the passenger’s side, all pics from here on out are of that side only. I used an old section of railroad track I keep around to use as an anvil, and gradually formed the patch to match the fender:
To give you an idea of how much curvature I had to put into it, here it is on the flat bench top:
Test fit against the fender:
Once I was relatively happy with how it was matching the curvature of the fender, it was time to drill holes to create the inside corners of the openings. The corners of the lenses where they’ll protrude through the metal aren’t perfectly square, they’ve got a rounded edge to them. I used a 1/4” drill bit which seemed to match the corners nicely:
To transfer this to the templates, I used a hole template intended for drafting to match the corners and transfer them to the templates:
Then it was just a matter of center punching them and drilling out the holes:
Next up was to make centering marks on the fender by carefully measuring the opening. This shows me where to precisely place the patch to locate it in the same spot as the original.
“But D, that’s all well and good, but how did you get from doing this to having the entire front end of the car all blown apart???”
Patience my friends, I’m getting to that.
Next, the fender was marked out for where it needed to be cut to accept the new patch, the green masking tape provides a nice hi-vis edge for me to follow when cutting.
But wait, we can’t fit and burn it in just yet, we’ve got no way of mounting the light to the backside yet! After using the light to mark the location of the mounting holes on the backside of the template, they were transferred to the patch, marked out, and 1/4” holes were drilled.
The process I’m about to outline next has proven to be the most effective way I’ve found to weld studs to sheet metal.
Using some regular old grade 5 1/4”x1” long bolts and nuts...
...I double nutted them to keep them fixed solid in the vise and cut the heads off with a regular hacksaw:
With that done, I repositioned a stud in the vise, and set up a nut just below where the stud will sit in relation to the hole:
Easiest way to think of this is the nut provides a “stop” for the sheet metal to sit on and is easily adjusted to set the depth/height at the same time.
Here’s a pic to illustrate what I mean with the patch sitting on top of the stud:
This is about perfect, the stud sits just below, allowing room for penetration of the weld, yet still be invisible and strong when the weld is ground down.
Burned in:
The backsides of both studs after welding:
Continued >>>
  • Winner
Reactions: 14 users
Rktpwrd
4,171
23,921
Here’s the front side, with the stud hole welds now ground flush:
Ok, NOW we can finally start to fit it to the fender and start tack welding it in. It all begins with careful and proper placement, but initially I wasn’t happy with the size of the hole I had cut. It was a bit too small, and I didn’t have the room I needed to properly align it to the reference marks.
More green tape to highlight where to cut...
...and finally, after many adjustments (patience was definitely a virtue here), I had it positioned where I wanted it:
Pretty boring stuff next, just tack weld, tweak and adjust, tack weld again. Here it is with a decent start on it:
And here it is, now fully welded and ready to be ground down:
Ok. Now, you may have noticed, I haven’t cut out the openings for the lenses before welding the patch in. This is completely, 100% intentional. If you go back and look at the pictures of the patch I’ve created, you’ll notice an extremely thin sliver of sheet metal that separates the two lenses. If I’m not EXTREMELY careful, and don’t do things just right, that thin sliver of metal will warp on me faster than you can say sh*t.
This is the reason I chose a slightly heavier gauge of metal, and why I haven’t cut the holes out yet. The heat from welding alone would be enough to send the entire fitment kerfluey. So I need to keep as much structural integrity to the piece for as long as possible. EVERYTHING has to be as near to absolutely perfect before I can even consider opening up the holes and test fitting the light.
Which finally brings us to last night, and the pictures in yesterday’s post. After finishing welding in the patch, I slowly and carefully ground all the welds flush, then inspected my work. Much to my dismay and despite my best efforts to control the welding heat, the patch had sank. Running your hand over it, you can feel where it noticeably dives in.
This is nothing to panic about tho, it’s completely fixable with some basic hammer and dolly work. Only problem is tho, this requires unimpeded access to the backside, as that is where the hammering needs to happen. Unfortunately, with the fender on the car, there is next to zero access to the backside due to the proximity of the inner fenderwell.
After some decidedly unhappy gnashing of teeth, I resigned myself to the fact that the fender had to come off the car to fix it. To get the fender off, the header panel has to come off. With the header off, might as well pull the front bumper so I can remove the bumperettes that bug me so much.
And so it goes.
I’m not frustrated or even upset about it, it is what it is, and is what had to happen to correct the problem. It’s not all bad, it gives me the chance to finish the backside of the patch and get some epoxy primer and paint there too to properly protect it.
I’d probably kick myself in the *ss if I don’t use this opportunity to paint the insides of the fenders too, but we’ll wait and see for sure on that. I’ve got enough to do as it is.
So there y’all go, there’s the ugly truth behind why the front end is all blown apart. Thanks for checking back, and stay tuned as the saga seems to be just beginning!
D.
  • Winner
  • Informative
Reactions: 14 users
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,697
Spring, Texas
Awesome as always!
