Well it’s Sunday night and I should probably share this past week’s progress with y’all. It hasn’t been earth shattering, but I’ve been told some progress is better than none, so here goes.
After replacing the broken passenger side door glass guide last week, I reinstalled the glass into the door and tested it out to check my work. With the window rolled all the way up and the door shut, I wasn’t satisfied with the angle of the glass which caused it to sit out and away from the weatherstrip.
(Nothing to do with the replacement of the guide, it was like this before disassembly).
After consulting my 1980 Body by Fisher service manuals, I found the section pertaining to adjustment of the glass and made the necessary adjustments.
Fits and seals the way it’s supposed to now:
It’s nice to finally see glass back in this side again!
I had also sprayed the braces for the AstroRoof insert last Sunday as you already saw, here’s a quick look at it all unmasked now:
With the underside of the pan/insert assembly now finished, I turned my attention to addressing some of the smaller details.
I had previously media blasted the front roller brackets and hardware, so it was finally time to lay them out and get them painted.
A couple coats of etch primer followed by a couple more coats of satin black had them looking good and protected:
Once they were dry, I reattached them to the roof insert. Note the small holes drilled into the brackets, these also extend through into the braces. This was done by me prior to disassembling the AstroRoof. By doing this I’m guaranteed perfect alignment on reassembly. All I needed to do was align the holes with the same size drill bit I used to make them and tighten down the nuts.
The studs on the rear brace get attached to brackets as well, but these are part of the cable drive assembly and as a result are not removable, so I just ran the nuts down onto them for now.
As I had mentioned in the last update, Mike had made great progress in tearing down the cable drive and track assembly from the roof cartridge to treat the rust issues we found there. While I still haven’t got the pre-teardown pictures from him, here’s the cartridge now stripped down and laid out on the stand:
He had removed all but the deepest rust pits, and treated the remainder with rust converter. The four corners were the main culprits, the water that made it past the outer seal must’ve been sitting stagnant here for some time to cause the damage.
Here’s after the converter had cured:
I temporarily laid the cable drive and track assembly back into the cartridge so I could show you how this stud is used to attach it.
Unfortunately however, I had broken the one on the other side when I went to disassemble it.
Using a hole transfer punch, I marked the location and drilled a hole the same diameter as the stud.
Thankfully the end of the stud had just a little bit of wider material on the end of it, so after cleaning the stud and surrounding area of paint, I dropped it through the hole:
After welding it back in and metal finishing it out, it’s good as new and you’re not able to see the repair:
The business side, like nothing ever happened!
Moving on, I scuffed and prepped the treated areas with wax and grease remover, red ScotchBrite, and plenty of elbow grease:
After that, I mixed up some epoxy and brushed the first two coats on and worked it into all the little pitted areas. Once the second coat had flashed off, I poured some on the most heavily damaged areas, and manipulated it around so it was more or less uniform.
The purpose of doing this was to have the epoxy act as a thin bit of filler. By pouring it on a bit thicker than normal, it would fill in all the pits and low spots and remain level on the surface. I got a couple of spots where it solvent popped doing this, but overall it was worth the trade off. Epoxy or not, I didn’t want to have those pits in the corners to hold water in the event it ever got in there again.
Continued >>>
