Donovan, the car is so close awesome. Glad you are still employed, my Daughter's boyfriend works at Flaman Rental's in the shop. Same situation, shop guys will be the last lay offs. Check out my rant in the Coronavirus thread. Get this done!
Donovan... appreciate all your work but I'd like to know about the 'spot priming'
As you stated you won't do the whole panel. So my question is won't that make the surface uneven? Just trying to wrap my head around it....
And thank you for your work and taking the time to document all of this.
Definitely challenging times.the olds looks AWSUME.
What's the story behind the two cutouts on front fender.
Been curious from introduction.
Donovan, I'm glad to see your updates. I can only speak for myself here, but I never tire of seeing the photos that you post, nor reading the description of what you're doing. I was kind of slow to get into your thread here, but since I've started following it, I find myself looking forward to your updates.
I'm sorry to hear that your hours are getting cut back, but that appears to be the reality of the current situation. I work for a transit company, and so far at least, we're being considered as an essential service, so I'm still working. The precautions that we have to take at work these days are getting kind of silly, and it was getting stressful, so I'm on a week's vacation now, just to relax a bit.
I was checking out the photos that you've posted, and in a couple of the photos, there is a reflection of one of your shop lights in the front fender. Is there any sealer on that fender, or is that just as a result of the grade of sandpaper that you're using, combined with your block sanding efforts so far?
I’ve been wondering why you used 2k rather than a spray polyester primer? The spray polyester has a lot less shrinkage than the 2k. The drawback is that you have to spray 2k over it before painting.
I left a 1” think puck of each, spray poly and 2k, sitting on a window sill for a few months. When I checked it the spray poly was the same size, the 2k was less than half and it cracked. I was pretty impressed.
