Well after cursing the paint techs on the idiot box at Kindigit Design on Bitchin’ Rides tonight, I decided I better get out in the shop myself and put up or shut up.
I received the header bolts and collector reducers yesterday via Amazon...
...and after cleaning and shooting the bolts with some VHT Satin Black (yes, I took the cheap and quick way out), got them installed and tightened down. Headers are now officially installed.
It took a couple of days to track down all the necessary brass 1/8” fittings, but I got the oil pressure tee for both sending units assembled and installed under the distributor tonight too:
No lengthening of the wires required, both pigtails reached perfectly.
Here’s a quick shot of the 2 1/2” pipes as they’re currently routed underneath the car, looks like I should be able to slice and dice to move stuff around without having to buy any more pipe. 👍🏻
And finally, I got the collector reducers mounted up with stainless hardware.
I’ve just gotta pick up some 90 degree boots for the MSD wires this weekend and get the straight ends swapped out, then the car will be in operable condition again.
Then it’ll be onto cutting and welding combustion byproduct evacuation transfer vessels!
