Well guys, today we dug into Olds Cool’s heart. Fairly deep into it as a matter of fact.
And we found....
....nothing.
Absolutely nothing. We found one torque converter bolt that was one thread loose, but that’s it. No smoking gun, no “aha” moment, bupkiss.
No sparklies in the oil OR the oil filter, no cracks in the flexplate, no loose flexplate bolts. On the front end, we tore it right down to the timing chain and beyond, everything looks perfect there. No loose timing chain or cam bolts, no loose pulley bolts, no failed elastomer on the balancer. No spinning seal in the cover, no walking crank key, no walking sprocket. No slack chain. No flat lobes on the cam, no upper valvetrain issues.
Fuel pump, it’s pushrod, inside of the timing chain cover all look mint. No rubbing on the transmission inspection cover. We pulled the distributor, inspected it and spun the oil pump by hand. No issues anywhere there either. We also inspected the front main bearings that we could see with the cover off. No signs of spinning or excessive wear or any movement.
Nope, we went after a lot of potential areas today and came up absolutely empty. Kind of a good news / bad news situation I guess, good that we didn’t find any catastrophic failure of anything, but also bad because we couldn’t find anything wrong.
The next step I guess is to reassemble it and give it the full send treatment. Whatever it is will either self clearance and go away, or it’ll fail in spectacular fashion and make its presence very well known.
Frustrating to say the least.
