Just watched to the IG video- yeah that's pretty loud. Maybe a dumb question but is the balancer bolt tight? Harmonics can be a weird thing, maybe new exhaust is vibrating something that wasn't being vibrated before?
That's one of Mr. Sony's Buick 350's. It's a bit unnerving seeing those busted flexplates walking around like that.Thanks for those, I appreciate it. If I had to say, mine sounds a little bit like the first or last video. I’ll take another one here in a minute and post it up.
Did you have the jack under the oil pan? Any chance it is now contacting the rotating assembly? Doesn't seem likely but I'm trying to come up with a scenario where jacking up the power team led to the noise.100% agreed with you there Jared. I’m not ruling anything out at this point, but all I can relay is what I’ve found to be the case so far.
What I found is curious is that this noise is new and didn’t make it before the header installation. I don’t believe in coincidences, usually if a new symptom arises after work done, it’s usually related to what was just done.
We did have to jack up the engine off the frame stands on both sides to fit the headers in, but we did it carefully and methodically. Didn’t take any unnecessary risks or push things beyond where we should’ve. Nothing was disturbed at the flexplate other than removing the inspection cover for more room.
