Awesome work Donovan.Here we go guys, I got the driver's side marker light patch welded in tonight.
I needed to trim the patch panel I made down a bit, so I started by bolting the patch over top of the existing hole after I laid out my centering marks:
Yes, I know the bottom marks don't line up, but the other 3 did, so that was good enough for me.
After getting an idea of where the material on the patch was needed, I trimmed off the excess and traced around it on the quarter panel:
Time to get cutting. Outlining my marks with masking tape so they'd be easier to see, I cut the rusty crap out with a cutoff wheel.
I got a kick outta this (I've seen it before on The Juggernaut), but with the hole cut out, you can see this stamped in the lower trunk drop off:
Pretty cool.
Using my sheetmetal welding clamps, I got the patch positioned for welding:
I'll skip past the boring and monotonous welding part, and just show the pic of it fully burned in:
Continued >>>
The last time I welded in a square patch on a broad flat expanse of sheet metal like that I had a lot of trouble with distortion, particularly with the corners wanting to suck in. I attributed it to shrinkage from each tack cooling. Have you encountered this, and how do you prevent/combat it?
