D, as usual, your superb level of craftsmanship just blows me away. Your thread has been very compelling to say the least... and extremely well detailed.
This car is turning out to be more of a show piece than even a casual daily driver.
Keep up the great work, Mr. Riddler....😀
I'm glad to see that you're feeling better, and that your enthusiasm has returned.
Looks great as usual Donovan!
Thank you Kevin!
Speechless! Totally amazing.
Thank you!
Donovan, it's no surprise the level of attention you spent to an area that most of us overlook! To grind out the seam sealer, re-apply and scuff smooth is a nice touch to clean up the factory applied mess that once was!!!
As usual, great work and the results speak for themselves!!! Well done Mr. Ridler 🙂!!!
I appreciate the sentiments Scott, thank you. It’s never been my intention to try and impress anyone, I just felt sanding the seam sealer down in the high visibility areas would look much nicer.
Yeah, hey, no sh*t on the just ridiculously irresponsible use of sealers and adhesives at the factory. Needless to say I had quite a surprise when I got down to my floor pans. Most say just cover it back up but I'm WAY too anal for that. Plus you just can't tell how thick it is on those pics? I've got it about 1/2 gone so far, reapplying primer when I get to metal. I'll have pics over on my thread when I'm done. Slow going, partly just because of my wimpy *ss lupus hands but the heat gun is working wonders. Then just adhesive remover when I get it scraped down to the pan.
I wish I had your talent Donovan. This car deserves some kind of special award when you get done considering I think most would have given up on it but, no, she still has a lot of life left in her . . .
Thank you Garth.
I’m not expecting to win any awards or popularity contests with this car, I’m just trying to do the best job I possibly can while I’m here. All these areas obviously need the attention, so I might as well fix them as I come across them. Unfortunately that’s also how these things sometimes snowball outta control!
One thing and one area at a time. That’s all we can do. Good luck with the 442, keep picking away at it as your health allows.
Great attention to detail, and an awesome result, as usual!
one of these days, I'll get the Chief's thread started, and you'll be able to see how close the problem areas are mirrored all the way through to 1987.... I have the rustout right above the trunk hinge on the passenger side that was next on the list, but I got caught up in another "while this is out" look.....
Darin
Darin, thanks for the insight as to you having a similar problem with corrosion in that area. It’s somewhat reassuring to know that mine wasn’t an isolated case. I’m gonna chalk it up to a design flaw.
And thanks for the compliment.
Nice work, nice result 🙂
Thank you sir!
Beautiful work as always Donovan. You've saved that car.
Much obliged for the comment Jared, thank you. I think I made the right decision starting the restoration of the body when I did, too many more years without attention and I think it’d have been too far gone to save.
I just hope the end results will justify the work that’s going into it...
Thanks so much Jack.
I know full well that I tend to go into more detail than what’s probably necessary, but I’ve always thought there’s no such thing as “too much information”. If my detailed posts and information can serve to help out even one member working on something similar, then I feel it’s well worth it.
Thanks to everyone for all your comments and support. It really is appreciated.
Donovan
With the seam sealer sanded and blended nicely, it was time for my least favourite chore, masking.
I am a masking bandit! I just can't paint worth a damn. I have almost the entire black interior collected to swap for the sun-beaten camel, just need to paint the car first. You'd be bored, though...almost no rust to speak of.
I am a masking bandit! I just can't paint worth a damn. I need to quit my day job, run away from my family and become your shop apprentice for couple of years. After that, I might make more progress on my coupe. I have almost the entire black interior collected to swap for the sun-beaten camel, just need to paint the car first. You'd be bored, though...almost no rust to speak of.
Oh, I highly doubt I’d be bored Quinn.
There’s always something that I’d love to add my own little “twist” to!
You’re more than welcome to come up here and shadow me, however I’m pretty sure the weather here would be a major deal breaker for ya! It’s DEFINITELY nothing like it is there in New Mexico!
We’d probably make a great team, I love to paint but despise masking, sounds like you’re a masking whiz but need help with your painting technique!
Donovan, did you top coat with the Omni white or the PPG stuff you mentioned a few weeks / months ago ?
Either way it looks KILLER !
Thanks very much! I’m very happy with the way it turned out. More so, I feel better knowing that the protection is back in place back there under the taillights and other components.
As for the paint, it was indeed the Omni single stage for the color over top of PPG DP401LF epoxy primer.
As for the high build solids primer, I took your guys’ recommendation and went with the ShopLine stuff instead. I haven’t had a chance to use it yet, so I’ll reserve judgement on it till then.
Reactions: axisg
Hey guys
It’s been a bit again since my last update, and to be honest progress has been dreadfully slow lately due to an increased workload at work, but I’ve got enough info and pics to warrant an update.
Since spraying color on the back of the car a couple weeks ago, I decided to start reassembling the back end a bit as the remaining work to be done will have little effect on this area. I decided to start with the taillights, but of course I can’t just reassemble anything without making sure it’s worthy of going back on in the first place.
So I decided to disassemble the taillight assemblies and refurbish them due to their condition. These taillights are kind’ve my own hybrid assembly, they utilize the factory 1980 housings to retain the fibre optic leads, however I use 1978 only chrome rocket emblem bezels and matching lenses because I much prefer the look over the factory ones.
I started the restoration process by thoroughly washing all the parts in the sink, and scuffing the housings with red scotchbrite. After another cleaning but with wax and grease remover, they were sprayed with plastic adhesion promoter and followed up with a couple coats of satin black on the outsides.
Disassembly:
Backside of a housing after painting it:
The insides of the housings received the same treatment, except they were sprayed with a high shine/reflective silver.
While they were drying, I sourced some nice stainless washers from my stash and made up some matching rubber ones to seal the mounting studs to the body.
Here’s the first housing mounted to the body permanently. Yes I run amber bulbs in the housings, I find they provide a slightly softer and more “red” effect once they’re assembled. It’s a small difference that nobody would ever notice, but I do, and have been doing it for years.
With the housings restored and mounted, it was time to turn my attention to the lenses and bezels. The lenses didn’t require much work, a simple cleaning and a quick polish by hand with some Mother’s Mag and Wheel polish is all it took. Both of the lenses I currently have are cracked anyways, so they are what they are.
The bezels however have their own story. I actually currently have 3 sets of these ‘78 only chrome bezels, one set (and the set in the best shape) are on The Juggernaut. The second set I have, the chrome is nice and shiny, but they’re blistering away from the plastic underneath. They are the ones I’ve been using on Olds Cool up until this point:
The third set is where the story starts.
A couple years ago, I purchased a set of these ‘78 only bezels from a forum member here when he advertised them. Being trusting and foolish, I didn’t ask for pics of them beforehand, I just paid his asking price and waited for them to arrive. BIG mistake.
The member I bought them from was in Florida, but I didn’t give this fact much thought at the time. When the bezels arrived, I was completely dismayed and disappointed with what I received. Being in Florida, the salt air must have attacked and weathered the chrome resulting in extremely bad pitting and oxidation. Try as I might, no amount of effort or polishing could restore the shine to the chrome.
This is the condition of one of the bezels that I received:
I didn’t make a big stink about it at the time as I figured it was my own stupid fault for not requesting pics of what I was buying ahead of time, but needless to say I was very unhappy. That’s not really the focus here anyways, it is what it is at this point, and I just moved on. I took those bezels and chucked them into storage under the bench and pretty much forgot about them. Until now.
If you might remember, I plan on giving all the chrome and polished trim on this car the “brushed” treatment for a bit different and unique look. I didn’t particularly want to scratch up the nice chrome on the second set of bezels blistering or not, so I decided to have another look at the third set.
Because the finish was so horrible, I didn’t feel the least bit guilty about experimenting with them. Well long story short, I was able to make lemonade from my lemons. Or orange juice from oranges if you will! (Florida joke)
The chrome, while badly oxidized, took the brushing treatment very well. I hit the tight areas with red scotchbrite, but the main and most visible areas got a light sanding with some 220 grit by hand. I think they turned out really well all things considered.
After completing the “brushing” process on them, it was time to carefully mask them up to redo the black accents on them:
Continued >>>
Once all masked up, out came the satin black again. A couple coats is all it took to restore the look. Then unmasking.
Here’s the passenger’s side, now all finished up and installed on the housing:
At first, I had experimented a bit and painted the raised portion of the rocket black (not shown here) thinking it would accent the area, but once it was unmasked and installed, I immediately hated it. It just didn’t look right, and actually detracted from the area. Out came the lacquer thinner and the Q Tips, and the black was quickly removed from the rocket.
I think it looks good as is now.
It’s a subtle touch having the bezel brushed rather than straight chrome, but I like it. To me it looks tough but still classy.
What are your thoughts?
That’s it for now. Hopefully I’ll be able to make a bit more and quicker progress over the next little bit here before Christmas.
Stay tuned...
Thanks for checking back everyone.
D.
