Proportioning valve suggestion?
cdunson79
Nov 12, 2018
54
I'm upgrading the brakes on my 82 Elco. C5 brakes up front with basic rear disc on a Ford 9 inch rear out back. Going with a 90 Caprice master and dual diaphram booster but need to figure out a proportioning valve to use. Any suggestions? Maybe something like what was on early camaros that mounts below the master instead of down on frame rail.
Thx
10,566
14,302
The one used on the '79-'81 Trans Am with 4 wheel disc brakes is mounted under the booster.
L92 OLDS
2,872
3,051
West Michigan
I have used the factory disk/disk 1985 Cadillac Seville on (2) G body set ups. They work great, look factory stock and bolt right in without hacking up your factory lines. Also no unsightly valves and spaghetti mess near the manifold. Everyone seems to have their own solution that works but I like the simplicity of factory parts. The only down side is that this set up is not adjustable.
