Here is the deal. I haven't needed to buy a replacement radiator for anything since the late 1990s. Back then everything you picked up was copper/brass, clearly not the case anymore. I read about the purported plusses and minues of the plastic tank radiators online, the "benefits" of the aluminum core... Then because spectra makes a pretty good gas tank and I didn't see too much bad online, I tried ordering one of the Spectra premium radiators.
Not sure I like it.
The idea of a plastic end tank, plastic filler neck to screw the cap onto, plastic draincock, I just feel uneasy. In the car it is going into, there are not mounts or brackets that attach the radiator core to the support assembly. The radiator simply rests on its tanks on some tiny rubber pads, and the little plastic shroud on the top, with nothing wrapping around it either (no nice steel top plate that bolts on like the v8 cars) It just doesn't seem too durable to me???
That, and (unlike the Spectra gas tanks which are made in canada) these things are made in china. In fact, most radiators these days seem to be made in china. I'm thinking I want to return it.
The car it is going into is a plain jane Limited Regal. Probably 120 horsepower on a good day. While it is a lower mileage car and nice, it isnt a $30,000 show car or a 500hp drag car. I cannot bring myself to spend $800 on a radiator for it from becool or griffin. Yet, I want ultra relaible and to be able to hand the keys off to someone and know she will not be left on the side of the road, even on a 6-8 hour trip.
Does anyone know of the following:
* Made in the USA or Canada
* All-metal construction radiator with no bonding adhesive used
* metal draincock
* metal fittings for trans cooler lines
* metal filler neck
Priced around to under $200 or so that they have actually used?
Also...
Does anyone have the dimensions and measurements handy for a 1983 Buick 3.8 NA motor 2bbl carb radiator so that perhaps a universal fit would be close enough for me to use reliably from one of the better companies? The one that came out of this car is no longer straight after being crushed/twisted up... I'd be looking for total length, core length, distance from edge for outlets and cooler lines.
thanks!
Not sure I like it.
* metal draincock
* metal filler neck
Also...
thanks!
