Radiator support height after new bushings
-83MONTESS-
4,570
967
Bellevue, Ohio
Im in the process of putting the new-to-me radiator support into the Monte. I bought the new bushings from Energy Suspension but it seems the radiator support is still way too low. There is a huge gap between the top of the support and the fenders. What do you guys make of this? Double up the bushings? Can anyone tell me the stock gap size between the core support and the frame? I dont remember mine being much different than what I have now....
radiator support 2 by bwollens1983, on Flickr
radiator support by bwollens1983, on Flickr
lenny2001harley
46
6
nycta mta mechanic
I had the same problem I doubled them up and put some washers as well
454cutlass
315
24
mass
Looks like you have it up on jack stands under the doors. With an engine in a g body it will bend the frame down. Take out the jack stands and put on level ground. Should level out and not need washers
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I don't see any shims. The instructions say to reuse the factory shims and add if needed
454cutlass
315
24
mass
Yes sorry did use factory shim on the bottom but none up top. One or two shims is not uncommon
MR442
842
2
Back woods Central PA
2x on jack stands . The frame will flex allot . Should only need couple washers.
-83MONTESS-
4,570
967
Bellevue, Ohio
I got it figured out. Im using 7 or 8 washers under each bushing. When I put the shims in and tightened them down it was sitting on the ground. The bushings that came out are long gone and I do not remember there being any shims. This is a different radiator support as well so im not sure if there was a difference between some of them.
mhsmonte
131
8
Kentucky
-83MONTESS- said:
I got it figured out. Im using 7 or 8 washers under each bushing. When I put the shims in and tightened them down it was sitting on the ground. The bushings that came out are long gone and I do not remember there being any shims. This is a different <a href="http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=radiator support" class="skimwords-link" target="_blank" data-skimwords-id="1744451" data-skimlinks-editor="0" data-skimwords-word="radiator%20support" data-group-id="0" data-skim-creative="300003" data-skim-product="1744451" title="Shopping link added by SkimWords" occurrence="1" data-skim-node-id="337:Igotitfiguredout.Imu_2" style="">radiator support</a><span style="position: absolute;"></span><span style="position: absolute;"></span> as well so im not sure if there was a difference between some of them.
Thanks for the info on the number of washers needed... I'm using a different radiator also!
