Rear Anti Roll Bar for Drag Strip Traction
In the spirit of correcting bad information before somebody wishes they hadn't bought something else instead of this bar, I received it today and am extremely pleased. Out of the box the end links have at a minimum of 1/2" of adjustment between sides. If you were inclined to do a little bit of cutting you could easily get 1" of side to side adjustment.
The bar is 1-1/8" OD for sure. It also has a 0.140" wall thickness. Nice hardware including locking collars. No problems whatsoever. Everything measures out exactly right that I have no doubt that it will fit perfectly. I will have to grind out the mounting saddles to fit the 3.25" stepped 9" Ford housing in my car, and I knew that when I bought it. The saddles will be welded to the housing. I'll update with pics of the install on Saturday.
