Do I need to relocate my rear shocks to install the blazer rear brakes?
Many times you run into caliper to frame clearance issues when they are mounted that way on a G body.You wouldn't need to if the calipers were mounted towards the front.
I believe I can make that, looks simple enough.View attachment 180623On line purchase. I can't remember where from. There are several styles. Mine is the cheap one. The thing is that it must angle the shock towards the center of the car. Just spacing it towards the back will still not allow the shock to mount. It will hit the caliper.
I got the 2wd blazer rears they mount to the back I believeYou wouldn't need to if the calipers were mounted towards the front.
