GuysMonteSS said:I would like to think that UMI has tested these arms and they aren't going to "bind up and cause snap oversteer".
Shortly after I bought my Monte 14 years ago,I boxed both upper & lower control arms and installed poly bushings.I put this car through some very spirited driving over the years and never once saw any signs of the rear suspension binding or snap oversteer.
Guy
The thing is UMI may only intend these parts for race track use and not street use. FE3X Clone explained what I was talking about very well. One thing to keep in mind is that some performance parts, especially suspension parts may not be designed or intended for street use and only for track use, you just have to really know what you are doing and when it doubt stay stock until you find out more. If you ever had snap oversteer there is a high chance you would not be telling the tale. But with your current setup you have an increased risk of it happening. Also with your set up, your LCA frame mounts are now twisting, with 4 links something has to twist and the LCA mounts are not designed to take twisting since the arms are supposed to do it.
Of couse I am going by the pictures of the UMI arms in the link which appear to only have poly pushings and no roto joints. It could be an outdated picture and UMI could have upgraded to roto joints, but better check before you purchase.
The arms Anubis is selling are nice pieces and clearly do have the required roto joints.
