Do they clear 15" rims? I have a complete set up here that I was going to install on my Malibu but wasn't sure if they would fit.
Years ago I fabricated my own brackets using similar calipers. If I had to do it again I would use this Speedway kit. It will allow use of factory 15" rims.
GM 7.5 Inch 10 Bolt Bolt-On Rear Brake Kit
If you dont want to spend and arm and a leg on a rear disc brake kit and still have to weld the bracket on, weve got you covered. This kit includes two bolt-on caliper brackets, two 11-5/8" vented rotors, two GM metric style calipers, brake pads and hardware. 5 on 4-3/4" bolt circle Fits over an...
www.speedwaymotors.com
