rear end swap ( brake hose )
krazykyle
283
i swapped a stock rear end out of my 83 cutlass and put in a 67 chevy rear end.the brake hose for the 83 that mounts to the rear end is to short for the new rear end.it needs to be aleast 4 inches longer.anyone have any part numbers or swap out brake hoses that i can use for this situation.
Don't know if you would want to go this route, but, The rear brake hose on a 97 ish jeep cherokee (sport, se) could be a bit longer than a G body hose, it has the same type and size 3/16 fitting and similar mounting. If that one isn't long enough, a 79 ford f250 4wd brake hose will be. Most likely your local parts store may have either of them in stock. Oh yeah, and a brake hose for a 94 or 95 jeep Wrangler is said to be a touch longer than the cherokee's.
i need something that goes in the middle of the rear end and splits boths ways.the guys at the part store says there is a left and a right.
watching this thread... Im doing a 71 Olds 8.5 rear-end swap in a 81 Cutlass. Im curious of the same thing. What are you doing for wheels?
????? They are drinking their bathwater, and looking up front brake hoses. Either that or their looking up a grand cherokee.
Needs to be a regular cherokee "se" or "sport", it has the same type setup as a G body, tell them to look again.
This is what the cherokee hose looks like. The f250 one is longer.
that's the one i found on the internet also i have auto zone getting me on hope it's the right one
crap i got the brake hose for the rear end.the two lines on the rear end fit put the main line in the middle doesn't fit.the opening on the brake hose is to small.what now?
