Rear lower control arms
8,230
17,693
Bean counters figured a buck’s worth of reinforcement is cheaper than paying for welding and then coming up with new part numbers and logistics for the new part. This way it’s easier to use the same part for all the applications and use an insert when a sway bar was called for.
You can always modify the existing arm by tacking the insert in place and welding plates on the bottoms if you really wanted to.
JD1964
375
509
Exactly what I was assuming
JD1964
375
509
The bolts weren’t perfect but they were surely good enough for reuse. Everything went together nice. The bar and inserts got a double coat of POR15 before the install. For a 70’s station wagon, it handles pretty decent. Needs new front tires though. Not low tread but aged, hardening and beginning to dry rot.
