Rear view mirror falling
Rudy913
646
68
New Orleans
the rear view mirror keep falling off the metal peice should I just buy and new mirror? Does anybody have the same problem
I think it's a hot climate issue. One of my cars I have to re-glue the mirror at least once a year.
I find if the car sits out in the sun, the mirror bond is going to fail eventually.
Mine fell off I took it to a shop that repairs windshields and what not they charged me like 5 bucks to put it back on
View attachment 85005 View attachment 85006 the rear view mirror keep falling off the metal peice should I just buy and new mirror? Does anybody have the same problem
Something you've got going on is helping the screw loosen up if that keeps happening.
Worst case scenario is:
1) get the mirror seated on the metal pad
2) ink the screw tip
3) install screw tight
4) remove screw/mirror
5) gently, CAREFULLY, use a bit for drilling metal to make a shallow indent into the metal plate in just under the screw diameter
6) install mirror/screw with something for the screw to bite into and hold on the metal plate end.
