1983regal said:t01blaze said:when the bearing goes bad it usually takes the axle shaft out with it. the rollers roll on the shaft and they destroy it when the bearing goes. if you have another car to drive then i would take it apart first and then examine the axle shafts. you might need a "repair bearing" instead of a standard bearing and seal.
Most " Saver Bearings" I have installed on peoples cars were because the seal wore a groove in the axle and would not seal anymore. The Saver Bearing is a seal and bearing in one and places the seal in a new location on the axle.
a rubber seal cannot wear a groove in a metal axle. The bearing canwear a groove in the axle and that's why an axle saving bearing can be used. The axle saving bearing runs on a section of the axle further out on the axle.
