Rearend shifted
20,397
Yes I had it checked for rust but there was nothing major found and as far the rear alignment we measured from the center point of the car to the rearend and the measurements were the same
I would measure the gap between the frame and rockers on each side
39F
530
602
Pittsburgh PA
Im thinking probably lil far outside the box here but check your axle tube if it broke the spot welds and rotated that would also let the tire move forward due to the mounts no longer being at the same angles any longer especially a 7.5 rear
