Removing rear seat on 84 Regal
84Deykno
24
I got the bottom piece out no problem, what kind of tool is required to remove the two torx bolts (t-47 I think) from the straps holding the rear seat and seat belts?
shortydoowop138
117
Palm Springs, CA
Just use a torx attachment & a wrench to take them out. If they're already loose then a good set of pliers or decent screw driver might work. Id only use the pliers/screwdriver as last resort or if you don't plan on reinstalling the belts.
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
before you try to take out the torx bolts slide under the car and lubricate the bolts...then with the torx bit on an extention give it a couple of good shots with a hammer to seat the torx bit and to free up the bolt...
