Hey guys, wondering if y’all could give me a few pros and cons on either replacing the TPS or replacing the whole carb? I’m pulling a code 21 (faulty TPS). Car is a 1985 Cutlass supreme 307 Olds V8. Thanks in advance!
Never had much luck...guess I picked the right car. 😂Are you sure the TPS itself is the problem? Could it be wiring? You should be so lucky.
If it really is the TPS ....
1. Replace the carb. You're looking at "remanufactured" (aka "reman"). But the thing is so complicated, and has so many complicated adjustments that need to be done and done right, that upon receipt it must be taken apart and all done from scratch. Because you cannot assume that whoever did it was properly trained, got out of bed the right way on that particular day, properly supervised, etc. I'm looking at one right now, and know whereof I speak. Several special purpose tools are required, which these days are hunted down on Ebay. And of course you need a rebuild kit, in addition to the always lovable shop manual.
Oh and I forgot -- Even if your reman were somehow perfect, once installed you have to adjust the idle mixture screws. This requires a dwell meter, yet another special purpose tool (at least this one is easy to find), and a time-consuming tedious procedure all its own.
Another point I forgot -- Your reman comes with the TPS adjustment hole conveniently plugged. On that, see the following ....
2. Replace the TPS. Is the TPS adjustment hole plugged? It was from the factory. There's a ridiculous procedure where you drill a tiny hole just so far without destroying anything, insert a small screw and pry on the head to pull the plug out. There's a cute hand drawing of the drilling step in the shop manual. Once past that, with the new TPS installed and the air horn back on, the new TPS must be adjusted. This requires a long-snout 2.5 mm hex socket that will fit in the hole. Once adjusted a new plug goes in the hole, or the adjustment will creep. The alternative is to use Loctite, but I don't know how well that works. A replacement plug comes in the rebuild kit.
It's your choice. I won't say "good luck" because I've been there, and your luck is already bad.
I’m leaning towards a new carb (reman) unless I find a carburetor guru out here in San Diego to rebuild this carb.
I will disagree that it is flimsy.
It's pretty much a bolt it on and go after he gets done with it.
