You know what I would do? I would save 50-100 bucks off those eibachs and get moogs all around. Then spend that money you saved plus another 100 for fully adjustable shocks.
Reason being, those eibachs are nice but they're variable rate. Variable rate springs are nice in theory, but 90%+ of your driving only will use a certain part of the spring - the part which isn't variable. Your jounce bumpers, if you haven't removed them (if you don't have them you can buy these cheap) work the same as a variable rate spring without the extra cost. They also work dead on each time, for example, if you hit a pothole with variable springs, you could be at 3/4 lock sometimes and full lock at others so your suspension handles a bit differently each time cuz they're variable. With regular springs and jounce bumpers, you know how your car will feel and handle going over a bump each time - then at full lock your jounce bumpers kick in and it's like clockwork, every time.
But I'm just giving you info, I'm sure the Eibachs are top notch, but you gotta remember the springs will only do so much for your suspension - they only improve your ride a certain amount, it's the shocks that really make the combo work.
If you really want to save money, bring your current springs to a chassis/suspension/welding shop that has experience cutting springs. You could have 1/2 coil cut and the springs reshaped for much less than new springs. This will lower your ride a little and make it a bit stiffer. Edit - you don't really want to go lower than half a coil, it messes up the integrity of the springs, you can also repaint them, hell you can paint them body color if you wanted, so they look like new.
