Rocket 350: I need Headers and Exhaust Feedback
I would love to see that video if you still want to post it.
Also, I want to get some information on how that Cam workout for you. I have a 71 Olds and I'm looking at Cam options too.
I think I have a video of my car idling on my computer. I'd take another video but I have the car parked for the winter and have the carb off of it to rebuild.
As for the cam the paperwork the guy gave me with the car when I bought it is for an edlebrock performer rpm cam. The motor has plenty of power but I cant say I've pushed it to its peak yet. I swapped in a 200-4r trans and right now at wot it shifts at 4k rpm. I think the motors just getting into its power range when it shifts. Fixing the shift point is also on my to do list over the winter. Heres the link to the cam
http://www.edelbrock.com/automotive/mc/camshafts/oldsmobile.shtml
This may sound like a stupid question, but please, educate me, on this. What gear would you like to be in during peak performance?
If you have the rpm cam then you need the GN governor put in, should put it near 5500 rpm full throttle. Hopefully your converter is 2500+ stall.
I was either going to get the gn governor or take weight off the one I have now. And I made the mistake also (not doing enough research) of putting an 1800 rpm stall converter thinking it would make it more streetable. That is also on my to do list, price and install a 2600 rpm stall converter. Im new to all this so its been a learning process.
Im no expert but this what I've got out of my research. It's not really what gear you want be in but what Rpm your motor is at when it shifts. Motors will always make top H.P. towards the top of it's rpm range. If my motor redlines at 6000 rpm. its going to make its most power somewhere between 5-6000 rpm. Because my transmission is shifting at 4000rpm when Im at wide open throttle I'm not getting the full horse power of the motor. Im sure someone else will chime in if I said anything thats incorrect.
not totally true, it depends how the engine is designed/built. Most of the Olds motors I have over the years peak in hp&tq in the mid range RPM's..
Reactions: WisconsinCutlass
Trust me, a lot of weight needs to be removed to get where you want plus it is trial and error. The small weight raises part throttle and the big weight raises full throttle, I believe. I have mine shifting at mid-high 4000 rpm's with the green line bias spring from the big Trans Go shift kit, raises shift rpm by 300 to 500 rpm and shaving the weight a bit. For a torque converter, contact PTC and ask for the same converter as Dan Mascal uses. A 2800 stall 10" tight around town for around $400. Dr Dan as he is known on ROP was a GM tech for years and actually builds the 2004R for himself and others and knows how to make them live behind Olds sledgehammer torque. He also runs Olds 403's very fast using Qjet's for carbs as well. I have the cheapest PATC 350 hp converter rated 2200-2500 stall, tight on the street and flashes at 2300 rpm behind my 350. I plan on using a staked with a screw Monte SS or GN governor, the spring has a tendency to fly out, upgrading my extra pump to put out 250+ psi vs my current 215 psi and getting the Dr Dan converter. I am upgrading to a 217/223 custom cam in my Olds 350, should be much better than the lousy, too small Performer cam. I am also planning on 3.90 posi and maybe a Holley sniper in my Olds Cutlass 70 S. But for next year, it will be Dr Olds mileage machine with an Olds 260 with mild mods, dual exhaust with a H pipe, open top air cleaner, Startus electric fans, 88's current 2004R with braided cooler lines and 2.78 gears. My 88 CSC will see race duty, stripped interior with 424 Olds stroker 403, TH400 and 9" with 3.89 locker eventually.
Thanks for that info.
