it just dosnt seem worth it for only 40 more horsepowerAs long as carb 350 direct swap
And 40 HP can make a BIG dif
I know that I refer to my 97 Monte a lot but its an example in this case. It had a 3400 making around 200 HP. Swapped to an l67 making 240. The l67 was a totally different animal. As in I had to relearn driving the car
I didn't say it wasn't useful or popular, I said for an old car, like ours, that had 8:1 compression at best from the factory with teeny tiny camshafts and really conservative timing, it's just watered down gas. Now, take a car like a GN, and it'll run great on E85 with some light mods, because of the boost as you brought up. What I'm trying to say is that for a bone stock car from the 1980s, unless it has boost being shoved in it, E85 is just cheap watered down gas. There's no benefits to running it at all in a low hp, low compression stock, NA engine.Actually no. E85 is popular because it allows both high cylinder pressures(like high compression or boost) with REALLY aggressive timing.
