i have to refill all, from max to min in 200 miles.CHRIS.O said:Answer some questions for us please. What do you mean you have to refill the oil? All of it or just top it off? Secondly how do you know your compression is good? Did you hook up a compression gauge to each cylinder? Do all the plugs oil foul or just a couple. You should use some type of sealer on the rocker studs that go all the way through. The way you make it sound I would have to agree with Ritter and say you have some ring issues and lots and lots of oil burning going on.
i did an compression test on cyl 7 (one of the failing) and it was 10:1
im not sure the rocker studs ar 100% responsible for all this, but what else could it be??
