So I am attempting to set my Monte up with an AC system, the factory set up has been long gone for many years and the space it used to take up is filled, so I am attempting to install this with the least amount of change to car
So my plan to make mounting brackets to install a belt driven Sanden 508 compressor up front that will be driven directly by a crank pulley but I will be using a Vintage Air Trunk Mount Evaporator. https://www.summitracing.com/parts/vta-685000-vuy and a remote mounted AC condenser with electric fan under the rear of the car mounted to the roll bars at an angle.
https://www.oldairproducts.com/prod...assy-w-shroud-and-11-electric-fan-11-1223sfrm
The ports will be on the lines coming off the compressor
https://www.summitracing.com/parts/vta-35136-vuq-a
And I will also be buying a drier from vintage air and once everything is in place I will need to get custom AC lines made.
I will also be installing a RPM cut off switch since I spin this engine pretty high.
Any input, suggestions, comments are welcome I am only in the beginning stages of setting this up but it seems this could work.
