Shifter cable ???'s
dickeymoore
924
Atlanta,Georgia
I have a 79 Chevy Malibu buckets and console car with a 350 transmission I am going to be converting it over to a 700R transmission I know I have to shorten the drive shaft and all that but will the original shifter cable bolt to the 700 R4 transmission pan or what do I need to do for it to bolt to the 700 R4 transmission pan thanks
84cutspreme
1,146
152
I used stock shifter cable for 80’s camaro w/ 305. used stock camaro shift bracket and lever at trans. modified cutlass shifter in pics below to accept 700 cable end
  • Creative
19,992
Your factory shifter is a 3 speed you will need a 4 speed shifter now or you will have to modfiy the gate in the 3 speed shifter
dickeymoore
924
Atlanta,Georgia
Yeah i know about the shifter not getting low gear but im asking about the shifter bracket that bolts to the transmission pan can the bracket work with the 700r4 transmission pan?THANKS
19,992
I dont believe the bolt holes will line up B@M marks a bracket that fits them all.
12,177
9,796
12,177
9,796
Yep i will just to find bracket fro. Camaro or firebird THANKS
Once you have the right bracket you could then determine whether the cable will be compatible with the 700 trans.
