Should I add bling to my engine to increase value or keep stock
8,818
7,763
chrome wont get you home
not worth it
plus that cheap chrome crap always leaks.
And rust as well. Now quality, thick flange steel chrome or polished or powder coated aluminum is a different story. Some nice finned aluminum valve covers would look tasteful on there.
Mac442
257
384
Ocean County, NJ
I remember those Mr Gasket chrome thermostat housings (water necks) that people would install as an easy “bling” mod back in the day…until the gasket started leaking, and it turned out it wasn’t the gasket, the flange was distorted and not flat.
What I’m trying to say is careful with the chrome parts. A lot of it is cheaply made, they hold onto heat and are a Pain in the *ss to keep clean if you drive a lot,
scoti
1,972
3,384
Texas
Changing things to 'bling' up an engine compartment can be a dbl edged sword.
You add some shiny stuff that you like & feel your price reflects the investment but that doesn't translate into automatic value w/potential future buyers. If you want to bling it up, do it because that's how you want it to look w/zero expectations of recouping that investment. If it does help after that during a future sale, it's just icing on the cake.
8,818
7,763
The cheap chrome Olds V8 thermostat housing are impossible to seal. The expensive RobMc and BTR billet water necks seal fine. The cheap chrome valve covers needed basically straight RTV Ultra Black or the rubber with a rigid core for any chance to seal.
9,609
12,663
Imagine if you did ALL that above to that 565, and then....it didn't start. That's when bling means nothing. If it runs great and always starts, then you can worry about bling. And I'm sure the basics were covered before any of those fancy hoses and polished parts went on that engine
Since I do my own engine assembly, I am not worried if my engine will start and run and I install most stuff on the initial install after doing mock ups on the stand including a majority of the braided lines like I recently did for my 355 SBC in my Regal and then do some add ons at a later date.
86LK
1,963
2,027
as people who have Harleys find out when they have to constantly keep polishing their exhaust pipes
6,824
6,721
So, in short, do what you want. But to avoid headaches, spend a little extra on nicer dress up parts. Dont cheap out, it will bite you in the *ss.
