So I got my block back from the engine shop. Cleaned all the oil galleys, painted the lifter valley and the timing chain area with red glyptal, taped the entire engine off and cut around the gaskets before painting the outside with KBS motor coater. Today I washed the block, dried with compressed air and used wd40 to coat the machined surfaces. Problem is I have what looks like slight surface rust in the lifter bores only, nowhere else. What do I do? start all over? Did I do something wrong? Any help would be appreciated.
