Slow wipers: Help
When you take the motor out just take out the two top 10mm bolts and then just pull up on the motor. It will come out and the lower grommet and bolt can be left in place. When you put it back you can slide the forks into place in the grommet
Thanks for the tip GP! I would've taken all three out.
I would turn them on with everything hooked up and give the motor a couple taps with a hammer to see if the brushes are sticking or has a bad contact.
