smoke coming out of my breather
illregal82
262
MINNEAPOLIS
my freind said my guide plates are going bad cause there is some smoke or steam coming out of my breather on my passenger side valve cover is this true :shock:
1fast87olds
140
St. Albans Wv
sounds like to me its blowby... oil ring is goin bad
BB Olds
Feb 18, 2007
83
Wi.
what about that was offencive
82355supreme
244
Wisconsin
Smoke out the exhaust..... yea if it's a two-stroke. :lol:
Now, seriously, how "fresh" is your engine??? If it is just rebuilt, it could very well have excess blow-by 'till the rings seat. My engine did this for about 500-700 miles after I built it. Mine still has a fair amount of vapor, but nothing out of the ordinary for a decent "built" small block.
Unless vapor & oil are running down the valve cover, I wouldn't worry about it.
One more thing... do you have a PCV valve plumbed into the back of your carb off the drivers side valve cover?? If not do it!!
rustyroger
502
6
Margate, UK>
heavy breathing
Get a compression check done, you should have something like 140-180 psi readings. If one or more is significantly lower than the rest its bad news I'm afraid.Good luck!.
8GPLE7
Mar 24, 2007
87
Az.
I had the same thing happen last year. First it was just smoke out the breather then the oil started blowing out. If I got on it hard enough you could see where the oil blew out the dipstick tube :shock:
I just put in a fresh 355 a coupla' weeks ago. I tore the old engine apart expecting to find some broken rings, but instead I found some broken ring lands on the #5 piston!! All the rings were fine.
Like mentioned above, get a compression check.
Cj
