Source for Quick Ratio Boxes? New/Used
mikester
2,921
3,687
Small town NY
Check out the website for Lares. Theyre a rebuild company. I have two of their boxes. You can order them through rockauto but the core shipping might be high. I bought both of mine at the local advanceauto. Took the cores right back to the store. It was still cheaper then rockauto.
Dayzedandkonfuzed
971
1,268
Anglemont, BC
I'm using the late 70's firebird box, ws6 i think, 2.5 turns lock to lock. Not super impressed actually, I ended up installing a pressure valve shim kit in the pump to firm it up a bit more, but it's still not where I want it.
Quick ratio manual box is in my future I think
melloelky
4,162
9,569
mass
the way the world's going as far as reman parts being subpar,how can one tell the difference between a closer ratio box over just another box with a four bolt lid?minus putting it in the car and counting lock to lock?you punch in the correct criteria on xyz web page/parts person @the part store-check out but how does one know they're getting that oh so desirable box when everything's remand these days and the source of these remands could be questionable ratio.
Dayzedandkonfuzed
971
1,268
Anglemont, BC
You're exactly right. Even a casting number doesn't mean a thing if it's been rebuilt. I know mine is the correct-ish box, but only because I'm right around that 2.5 turns lock to lock. Autoline reman carbs are the worst. I have never seen one with the proper jets, rods OR rod hangers. They just throw in whatever is handy.
roger1
537
767
San Angelo, TX
See post #24. More money but you get assurance and quality.
melloelky
4,162
9,569
mass
i agree 100%,i got mine from gm many years ago but this question has come up a few times and i've always questioned the validity of a reman'd box and the chance of getting burned by one.
Clarkwb100
44
38
Sugar Land, Texas
Replaced all body mounts, transmission mount, front sway bar, top & bottom arm bushings with polyurethane. Upper & lower ball joints, tie rod ends replaced and added rear sway bar. Did not do rag joint (no apparent reason) or the steering box. Handling is terrific!
One overlooked suspension piece is the tires themselves, correct pressure on the standard tires, max size or changing the diameter can have a tremendous effect on the handling.
Also, a smaller diameter steering wheel does effect the handling but sure gives the driver a different feel!
69hurstolds
8,198
17,599
Website is down at the moment. Says HTTP Error 404. The requested resource is not found. So I guess no amount of money works if you can't get to them.
Maybe they're updating stuff. Or they were hacked. Hmmm. Will try again later.
Drkuhar
512
912
Girard, IL
I used the Napa app and under 1984 Cutlass it had as choices with Hurst package ( same part number as Monte ss) or except Hurst package . Of course I ordered with Hurst package and picked it up today.
