Space saver spare tire...advice?
Roger,
I do have a posi, that's one of my concerns about using a donut spare...and also to be able to fit the tire well, which might be a problem. Time to take a measurement.
What size tires are you running in the rear? You can look it up on tirerack what the diameter is.
Roger,
I'm running 235/60 x 15 all around. The diameter is approx. 26.2"
You might be able to consider the wheel/tire I ended up going with. I got them both new for less than $150 delivered. Tire from Amazon and wheel from Summit.
The 215/60R-17 has a section width of 8.7". What size tire was the stock spare or what size did you have in that tire well last?
Reactions: Longroof79
Btw, what is the width of that tire well?
I took a quick measurement of the well. It's approx. 7" deep and about a hair over 26" length.
I'm thinking possibly a 15 x 6 rim....tire size would take a little calculating.... shouldn't be too difficult to figure out. I figured there wouldn't be any issues regarding brake clearance and B.S. being standard would not require the use of a spacer.
The tire that's currently used for a spare is one of the old 195/75 x 14's...which was the standard size on these cars new. If i can fit a slightly taller tire in the well, that would be great.
Thank you for your suggestions.
A 195/75R-14 has a section width of 7.7" and a diameter of 25.5". So if you've got room in the tire well for 1" more on width and about 1/2" more height, I think the setup I have would be a good one. The 215/60R-17 has a section width of 8.7" and a diameter of 26.1".
https://www.amazon.com/gp/product/B00MZB4Z5S/?tag=gbody-20
https://www.summitracing.com/parts/usw-84-7734l
Thanks for for the information on the size spare that you're using.... and the links to Summit and Amazon. I appreciate it.
