Help guys!
My speedometer let go the other day and my thought was that the cable wasn't hooked up to the cluster but everything seems fine and spinning the plastic shaft behind the cluster winds up the speedoneter so I am confident that the cluster gauge is functioning. I was told that the gear might be at fault here so my question is, is there a quick way of checking or do I have to take apart the tail shaft housing? Also what is likely to break the gear on the shaft or the little plastic shaft gear that most likely attaches to the speedo cable?
If it helps my car is fitted with cruise control but it doesn't seem to be working. Most likely because my speedo wasn't working. Would the cruise control have anything to do with it?
Sent from my SM-G935W8 using Tapatalk
