Speedway rear control arms
LsxBuickRegal1982
133
128
Has anyone used the rear control arm kit from Speedway Motors I was wondering would this be ok on my mostly street driven 82 regal lsx swap
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you don't want solid uppers with bushings on a street car, the OEM uppers are made to twist to prevent binding so if you use a solids you need a joint at one end.
LsxBuickRegal1982
133
128
Bonnewagon
Lost in the Labyrinth
10,564
14,298
Queens, NY
My lowers were rusted all to hell so I replaced them with the Speedway lowers. They are boxed, and pretty well made, in India I believe. 10 years with no problems.
Clone TIE Pilot
3,859
2,611
Galaxy far far away
With the lowers, you will want some sort of poly ball joints on one end to limit binding.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,779
Gainesville, Fl
When I boxed my stock lower control arms, I had Camaro 1LE high durometer rubber bushings installed.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
If you have the stock sway bar installed that limits the twisting of the lower control arms so boxing the lowers and using stock bushings won't cause any binding.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
I dont think that set has sway bar holes
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Could they make the print any smaller???
Note: The lower control arms in these kits do not have provisions for mounting a factory sway bar
This is why I avoid this place. They are real shady with the stuff
