Not bad I fixed a ton of sh*t that was wrong with the wire harness put the plugs in the wires on AC compressor electric choke tighten the headers installed the starter again put the inspection cover on hooked up all the grounds the batteries the alternator cooler lines lower hose heater hoses. I think all that's left is put the distributor in on the correct tooth hook up the oil pressure sending unit belts upper hose fan and shroud and the dreaded exhaust. Now I'm going to get that rest I needed. LoL
