Yesterday I took the truck to work. I wanted to address the running hot with the plow on. Even using the old keep it angled right and as low as you can she still creeps up way passed an acceptable temperature. So earlier this week I took some measurements with the old polish eyecrometer, did a little online shopping and bought a 10" electric fan and a temp switch kit. Yesterday I pulled the grill and radiator top plate cut loose the aftermarket trans cooler and installed the 10" fan on the driver's side of the condenser where I know there's no airflow with the plow on. I put the circuit breaker and relay on the left inner fender and tapped into the 12v power on the firewall where square body's have the 2 studs. It's wired on I ground switch thermostat sending unit thing I put in the intake. It's labeled 180-200 so I'm hoping it grounds at 180 and the fan comes on and cools it down or at least keeps it there. No time for testing supposed to get 4-8 today. I need to get my but out there and hook up the keyed power wire to the fuse block and put the plow back on I'm seeing snow flurries now. Sure wish I had time to get the radio working.
I figured come spring I can meeting up the wiring when it's not 20° out and I'm putting my motor back in.
