That's the hole point of the truck if I showed up in a late model truck and do a job I look like everyone else I show up in an old crew cab painted up standing tall it sticks in there mind if you rolled up and seen my truck and a new 450 what one would you remember lol it's advertisement on wheels baby! The 454 needs a go threw and if and when I do it I'll be relying heavily on the forum for build advise when I ran Chevy's I all ways had small blocks.I think that it will be impressive rolling up to do media blasting in the crew cab. Maybe TURNA has an actual chance of getting his frame notch!
It is a work vehicle. You can write that motor off on your taxes.😆Out of curiosity I just researched your suggestion and the prices are hell no!
Yea but I still need to lay out the moneyIt is a work vehicle. You can write that motor off on your taxes.😆
Do you know any casting numbers to make the search easier?You need oval or peanut port heads. The peanut port heads are meant for torque and aren't desirable for anything but a truck. Weiand even makes a dual plane Street Warrior carb intake for those heads that works with a Qjet.
Th400No, I am not a chebbie guy. It should be 80's and 90's truck motors till the Vortec heads came out for the 454. I also agree that nearly any Olds V8 beats a chebbie for a truck motor. That why GM went peanut port in the first place, trying to make it a low end torque motor. What trans is in your truck?
