It was no screamer but had decent low and strong midrange power. It was all done at around 4500rpm -- which shouldn't be a problem for you. Got great gas mileage.
A head swap is not an option at the moment I wish it was but I'm down on cash do to my recent bisness investments. Besides I hope to go with a much bigger motor unfortunately I don't have one ready to go at the moment or the money to get one readyWe have used RV cams in several engines. They work better in trucks that lack the gears. Beings you have steep gears I would go with a higher rpm cam. If money allows I would put some Vortex or hot 305 heads on with a stiffer valve spring. This is why I don't use the old trucks much any more. Good luck
Cam swap now. 3406 Cat swap later.
Well I'm guessing it goes back to all the half *ss work the previous owner did and I'm guessing it was probably not broken in correctlyCheapest crate motor+turbo= highway glory!
Are sure just the cam wiped? I'd be more worried as to why.....
