wait did u say you dont have a 12ga red for blower resistor? both ac and heat only cars still need this as far as i knew
Heat-only cars don't use a blower relay, just the switch and resistor.
I do not know to be honest. I just assumed heat only still used blower relay.Heat-only cars don't use a blower relay, just the switch and resistor.
I'd go 10; you're begging for problems. What's wrong with the old wire? That Packard wire is extremely sturdy stuff; just clean up the ends as long as it's not damaged in the middle. I don't understand your aversion to making it better than factory. It will be in split loom; the MCACN judges aren't opening your wire harness.12GA wire in purple for the wire to the starter.
how much too long is the wire due to the smaller starter? If the starter is smaller then do the wires not have to travel a further to connect to the solenoid?
